im consirering replacing my b16b with k20. can any1 tell me what wiring has to be changed etc. i am aware engine mounts driveshafts and gear linkage have to be changed but im not so sure of the wiring?? thanks
02-04 K20A2 Engine Harness....this is a rule of thumb for the majority of K-swaps but a 02-04 K20A3 will work and is a great/cheap option if you are not running a 6-spd trans. .
You also need a Conversion Harness for a EK (they have different ones depending on OBD2A and OBD2B) I have Hybrid Racing Conversion Harness but other companies offer them too.
Radiator Relocation Kit is a cheap way to deal with coolant
Different mounts b/c some guys run a EG subframe so they have more clearance and better header options (they are called EKK2 mounts.....old ones with EK subframe are EKK1)
