k20a into an ef hatch
Discussion in 'HYBRID -> ED-EF / DA' started by jspecef9, Nov 20, 2007.
  1. jspecef9
    jspecef9 New Member
    what exactly do i need and what do i need to do to make this swap happen? really really want to do a k20a swap into my ef hatchback but only know the basics need some help on the fabrication part.
    :confused:
    thanks ray
  2. norcalgsr
    NorCal
    There are mount kits and wiring conversions available as long as you have the cash to do the swap. Just do some research all the information is readily available.
  3. gursh d
    gursh d New Member
    check out K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
    here are a few write-up's on the swap:
    Ryan's CRX Page
    CRX K20A Swap
    you'll need a mount kit, and the only mounts I trust for k-series motor's are hasport's. Here are there instructions for installation:
    http://hasport.com/tech/installs/efk1.pdf
  4. invisibledemon
    Tn
    money.
