k20a2 head problem
Discussion in 'RSX' started by malito, Dec 27, 2011.
  1. malito
    malito New Member
    Hello i just recently joined this form & im having a problem with the head of my k20a2 motor. The problem is that my "valve seats", as the mechanic said, are bad & around my area i cant seem to find any. Can anyone plz help me out? :( explain to me what these valve seats are used for & where I can get it? I'd really appreciate the help
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    14775-PRB-A00 $1.85 each and you need 16 of them
    SEAT, VALVE SPRING
    They are what the valve slides through and it's the base of each valve spring to sit on.
  3. malito
    malito New Member
    thank you I really appreciate the help. These parts are all I need to finish my head
  4. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    Valve seats are what the valve seals against.
    Correct me if I'm wrong...
  5. josh_crewdson@y
    nova
    If those are bad, take it to a machine shop and have them cut the seats. Or if it isn't terrible, you can lap them by hand.
  6. CAFROG
    NOR-CAL
    Valve Seats based on the part number is as I spoke of in my first post. Thats the description Honda gives.
    Valve seat is also used (more commonly) as the ridge and seat of each valve port on the head (piston side of the head)
    If the above is bad.....yes....some machining is in order (I would have a machine shop do it.....most mechanics source that stuff out)
