K20a2 Swap
Cold_Cuts
7th gen civic eX auto wanting to do a rsx-type s motor and 6speed conversion swap.
any ideas?
:ph34r:
have lots of cash
you will need a half cut because u have to use basically everything including the under carage i.e. under engine support because the mount are different so have fun and have loads of cash
chad
just remember that the RSX type-s isnt that much heavier than your 7th gen civic...
stock type s runs on a quater mile around 15.7-15.8
so dropping the motor in your 7th gen will probably give you at most 15.0 and might break 14's
depending what you want to do......
your better off going turbo with your car..
i dunno
do some mad research and know what you want to do..
