K20a3
Discussion in 'HYBRID -> EP / DC5' started by Turbo02Si, Mar 6, 2008.
  1. Turbo02Si
    Turbo02Si New Member
    USA
    I have a 2002 civic si, that im looking to turbo charge. I have located a build motor (a3) and the price is 1200. its a used junkyard motor, but it runs and has about half the mileage on it that my current motor has. Is this a fair price or should i keep looking? Just not sure about condition, because i havent actually SEEN the motor yet.
  2. BrutalB83
    Rochester Hills, MI
    That sounds pretty fair to me. If they're open to negotiation I'd probably try and get it for a grand.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well if i was you i would spend another couple more 100 bucks or look around some for a k20a2
  4. Turbo02Si
    USA
    the a2 is 11:1 compression and the build im centering around was off my own motor originally. more Ivtec stages and a turbo means more time and tuning on a dyno.
  5. Turbo02Si
    USA
    Im swapping the internals out anyway, since they share the same block, it shouldn't matter. All the A2's i can find in the area are roughly 3000+. If i get the yard a3 i have a month to get 1200, no questions or debating. I might just wait. Not sure tho. im hoping to have the engine part of the build done by mid-end of summer
  6. AHHVTEC
    Alabama
    yea if your just gona build it anyhow get the a3 and a k20a2 for 3000+ is just crazy super crazy. you can get them cheaper than that. there was a guy on here not to long ago selling a k20a type r for 1700. but you can also get a k24 long block for 800 bucks
  7. Turbo02Si
    USA
    Do you know if the piston sizing and rod length (bearings etc.) are the same? Cause then I might just swap heads or some shit like that. Dunno its really up in the air right now
  8. Turbo02Si
    USA
    Do you by chance know iof any links or help I could get for an a2? I raced a buddy of mine earlier with and H22 in is EG and that 8000 redline is fucking amazing sounds (I got my ass handed to me)
  9. AHHVTEC
    Alabama
    of course you did, your car weighs alot more. but im not sure on the rod size
  10. BrutalB83
    Rochester Hills, MI
    Uh...H22s don't red-line at 8k, more like 7,500...
  11. AHHVTEC
    Alabama
    it depends on what ecu, you have i took mine to 8,000 every now and then
  12. Turbo02Si
    USA
    If you want to talk schematics of engines, its and accord euro r engine. and the car can go until the internals start to come apart at 9200 rpm on his car. His car also only wieghs 2200 lbs with him in it. does anybody know any trans people? I think id like to tweak the gearing in the car eventually.
