k24/20 built Integra..32MPG 270HP
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by kteggy88, Mar 11, 2012.
  1. kteggy88
    kteggy88 New Member
    New Price $8800 obo
    Hey testing waters on my integra.
    Reason for selling: need the cash
    Price: 10000 obo
    This Build cost over $12,000. If you know anything about the k swap, you know it's not a cheap build.
    never had a single problem with it at all. All of the work was done and tuned by Mikey from ProFunction..I believe it made close to 270hp/222ft-lbs. The car has 2000 spec front and rear bumpers. It has minimal rust bubbles in the quarter panels and some scratches that can be buffed out. small scuff on the bumper. It runs perfect. Oil is changed every 2k miles with mobile1 5w30. I only fill up with 93 octane from Shell.. Its a mid 12 second car with a set of slicks/drag radials.. Its a perfect daily driver.. Oil just changed a few days ago. all black interior. might need new brake pads soon (starting to squeak).If you want more pics, just ask! ac ps delete kit..still have ps pump if needed..Heater works great! I'll include the ScanGuageII with it also, it can find your mpg, mph, 0-60, 1/4 times, and tons of other stuff..If you have questions let me know
    96 integra ls (about 102k on shell)
    walbro 255lph pump,
    aem regulator
    bdl fuel rail custom coated
    modified type s injectors
    innovative mounts
    hybrid racing swap harness
    k-pro
    itr booster
    brand new itr master cyl
    rs brake lines/40 40 prop valve
    abs is deleted
    koni yellow shocks
    eibach sportline springs
    ssr lca's
    rs front seats
    bride shift boot
    faux itr cf interior
    jdm itr pedals
    itr rear seats
    alpine ipod deck
    clock delete
    jdm itr cluster
    k24a4 block from 2005 accord (about 3k on motor)
    12.5:1 cp pistons (rings spec'd between all motor and nitrous)
    blueprint I beam rods
    oem bearings
    steel k24 pan
    k20a2 oil pump
    k20a2 head
    k20z1 cams
    shaved/ported rbc manifold
    k20a2 tb
    karcepts cold air intake
    custom powdercoated valve cover
    carbon fiber plug cover
    04 type s transmission w/ oem type r lsd
    transmission in great shape
    comp clutch stage 4
    r-crew header
    magnaflow resonator
    3" thermal exhaust
    drilled and slotted rotors
    karcepts shift plate
    buddy club shifter
    oem rsx type s shifter cables
    tucked battery
    tucked bay harness
    stock 02-04 type s engine harness
    No joy rides
    Phone: Call/txt 502640159five
    located in Louisville, KY...
    Thanks for looking and please bump!
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    Nice, good luck with selling it.
  3. kteggy88
    kteggy88 New Member
    Thanks man!
  4. eg6sir
    sleeper status like whoa.. i bet you surprise the hell outta people with it.. lol
  5. kteggy88
    kteggy88 New Member
    Lol yup, that's my favorite thing about the car
  6. Team Arabek24
    Team Arabek24 New Member
  7. phunky.buddha
    Dallas / Fort Worth, TX
