k24/20 issues
wolydotmatrix
I was wondering if a 07 si lsd will accept the speed sensor ring from an 03 rsx
open diff and will the ring gear for the rsx bolt up to the same lsd
2. can I put tsx pistons on my accord rods
3.which water pump housing should i use (no oil cooler), i want to use the si idler and tensioiner assy.... the accord is missing one bolt hole ??????
