K24/20 type-s tranny
wolydotmatrix
Looking for some tech info.......
1. will the k24 wp housing accept the civic si water pump and the accessory tesioner and idler assy.????
looks ike I need to drill and tap 1 hole
2. Will the 06 civic si LSD drop into my 03 type-s trans and will the speedo ring on the diff transfer aswell?????
3. can I put a set of TSX pistons on my accord rods?????
i know the cranks are different and the rods are beefier but I dont have a TSX manual to get the specs I need
I can do the r&d on the tranny , but that is a big nut to drop if the speedo ring wont swap over ..I have full access to Honda/Acura parts but I hate to buy things I don't need ..........:eek::eek::eek::eek:
1) i dont think the water pump will attach on the k24 wp housing... you need a k20 waterpump housing if you want to run the k20 waterpump.
2)the 06 lsD will drop in...the speedo ring is digital on the 06 and the 03 is not digital...
3) you can use tsx pistons on accord rods.
