k24a2 compression
unlikelyhero
so i just bought a k24a2 off ebay for dirt cheap and now all i need now is axles, shift linkage, and mounts. Here is the build they did on the engine
bottom end consist of balanced crank, bored out cylinders by .02, wisco pistons 12:1 compression ratio over sized pistons, crower maxi lite rods, fidanza fly wheel, all new bearings, p&p head, dual valve springs, 3 angle valve job. ready for cams. Type S Tranny
I wanna lower the compression. help please.;)
