Kenwood amp audiobahn sub
Discussion in 'Car Audio / Security / Electronic Accessories' started by CrazyAzn, Aug 9, 2005.
  1. CrazyAzn
    CrazyAzn Senior Member
    okay well i have a slight delima here, i have a audiobahn aw1251se which has dual 4ohm voice coils. well i wanted to get a kenwood kac 7202 amp which has the following specs:
    two-channel car amplifier
    150 watts RMS x 2 at 4 ohms (230 watts x 2 at 2 ohms)
    460 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
    high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
    selectable bass boost (0-18 dB at 40 Hz)
    cooling fan
    MOSFET power supply
    CEA-2006 compliant
    preamp- and speaker-level inputs
    preamp outputs
    Tri-way capable (Tri-Way Crossover required)
    requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
    13-5/8"W x 2-5/16"H x 11-1/4"D
    would i be able to hook that up to a audiobahn sub with dual 4 ohm voice coils, because since im using a single subwoofer i cant find a way to lower the impedience to 4ohms, which the amp is rated at. i can either get the impedience to either 2ohms or 8 ohms which isnt exactly 4.
    does any one have any information on this? i emailed kenwood but havent recieved an answer and i cant seem to find it online, due to the massive amounts of audio websites.
    any help is great, thanks guys.
  2. crxdxb16a
    crxdxb16a Member
    Ontario, Canada
    Your best bet is this setting ------>150 watts RMS x 2 at 4 ohms.
    Just hook each channel to a coil. As long as you hook it up with a MONO INPUT the same power will be to each coil and it will run fine.
  3. CrazyAzn
    thanks, that sounds like a plan, ill look into it
