killswitch
JDMEG-6
wek sos
any helpful info. on killswitches... as far as.. how to do it properly? relays?
ingnition killswitch
and fuel pump killswitch
there are quite of few alarms that can have a kill switch relay interfaced with it. option group might be a cheap one, but it gets the job done. as soon as someone tries to start the car while the alarm is enabled, it will sound the alarm and won't let the car start. Then when you disarm it, it'll beep a certain amount of times to let you know what's been going on w/ your car. 4 chirps=tampered with 5 chirps=attepted startup.
i hooked up my alarm, cd player, an clock to the battery for constant power an the rest of the car is on the killswitch. Turn the key an remove it an no one can start it...
