Knock Problem + Check engine on
Discussion in 'Civic and del Sol - EG and EK' started by bono, Oct 26, 2012.
  1. bono
    bono New Member
    As above, I have an ek9 with b18c GSR swapped. Since one week, while driving and mainly on low rpm and re accelerates, I feel a kind of knock and the check engine light turns on. And when on idle, the rpm goes down at times under 1000. What may cause this? Sparks plug? I didn't change them when I did the swap.
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    what is the check engine light code?
  3. monotech
    monotech Member
    x2 check the cel and see what codes you are getting that will give you an idea what you need to look into. Idle below 1k isn't a bad thing 750-900 is a good range depending on your build.
