knock sensor code
94_gs-r
can you say 260 whp N/A??
i dialed in the cam timing and the crank to exactly 0,0 at steady engine speeds or in a higher rpm the knock sensor code comes on i set the ignition timing as close as i could get it with a timing light but it was all the way advanced and because of that code i cant use vtec, its a brand new factory knock sensor never came on before but i just did a build on the block so im at 11:5:1 comp, is that why its going off or is it cause the timing is not close enough? i have the factory gsr ecu, should i put the p28 in there to delete the code?
help please
the factory ecu probably isn't providing aenough fuel for you at that compression level, and thus, its knocking.
get it tuned.
