darwins_vtech
Hi. I have a JDM B16 SIR II swap (think its year is a 1999) getting ready to put into a 93 civic EX. I think that I have to run the wire for the knock sensor, but just to make sure, is the knock sensor the plug under the intake manifold and that is in the block/head. And if I break it off accidently, how much do they cost to replace(cause I think mine is broken). FUEL INJECTORS-- Can I use the fuel injectors and fuel rail that are from my EX in the B16 or do I have to chop the EX wiring and connect the B16 injectors and fuel rail to the EX wiring harness. Thanks guys
DARIN
DARIN
