Taco15
I wear stretchy pants
alright. since i got the car its had the knock sensor code on. Ive hooked up what i thought was the knock sensor ( back of the block above the oil filter). Ive fixed everything else and reset the ecu. What can be wrong? Bad knock sensor or is there something else that can make it throw that code? Also, is it robbing the car of power or hurting it at all?
Its code 23. i have a B16a/b18a1.(ls/vtec) i need advice here so anything is appreciated
