so i did a B17 swap into my delsol and im running a jdm p30 ecu (i know its jdm it came from japan with my jdm b16 head) so i wired the knock sensor into the ecu at pinout C2. the knock sensor was used but the guy said it worked when he took it out. Is there a way to test the knock sensor to see if its working or what can i do? i need to pass deq soon so is there a way i can by pass it for now?
