knock sensor problem
Discussion in 'General Tech and Maintenance' started by highperboi, Mar 14, 2004.
  1. highperboi
    highperboi Senior Member
    Alameda, California
    i was driving and my check engine went on. I checked the code and it was 23, check knock sensor and circuit. So i checked all my wireing and it is ok. I will check knock sensor later but the wierd thing is if i turn off my car and turn it back on the check engine goes away. But will return if i gas it hard or just rev it to 3000 and stay there for a little while. Has anyone had this problem? any ideas??
  2. randerson165
    randerson165 Senior Member
    Eugene, Oregon
    Have you adjusted your timing other than factory or do you have a cam gear that you have adjusted ? This was my problem.
  3. GSR-Star
    GSR-Star Junior Member
    Gig Harbor, Washington
    I have the same problem with my civic. I have a Vtec controller and was told that wiring with it was causing the check engine light to turn on. I'm not sure how reliable that explanation was and am also eager to hear suggestions on what I can do to stop that Check Engine light.
  4. highperboi
    Alameda, California
    my timing is at 18 degrees but it always has been. i havent dont anything resently to my car either.
  5. highperboi
    Alameda, California
  6. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    The check engine light only means that there is either a defective sensor or the wiring is bad. The actual knock sensor adjusts timing without throwing a light. Disconnect all of your wiring and re-solder it. Don't forget to reset your ECU!!! If it keeps doing, the knock sensor is fucked and you'll need a new one. They are expensive from the dealership.
