Knock sensor question
Discussion in 'HYBRID -> EG-EK / DC' started by toyzbus, Oct 9, 2002.
  1. toyzbus
    toyzbus Member
    Western Nebraska
    As stated in my other post, I am doing a mini-me swap on a 93 Del Sol. Well anyways, I am using a p61 ecu for this. The p61 is set up for a b17 w/ knock sensor. The d series doesn't have one. I was wondering if the knock sensors are normally opened or normally closed to ground. If they are n/o, I should be fine leaving that pin blank. If they are n/c, I will need to run a pin to ground to prevent the timing from being retarded. From looking in my Integra Helms manual, it looks like it is n/o. I just wanted to know for sure.
  2. pissedoffsol
    why in gods name are you using that ecu???
    run a p28
  3. toyzbus
    toyzbus Member
    Western Nebraska
    The ecu came out of my freind's 94 hatch w/b16a2. When he had it swapped the shop put that ecu in his car. I ended up selling him my chipped p28. Now that another freind bought my old motor to do the top end swap, we ended up haveing to use the p61. Is it a bad idea to use it, or is it just not as ideal as the p28?
  4. knowledge
    knowledge Senior Member
    Beale AFB, CA
    The P61 is for a DOHC VTEC and the P28 is for a SOHC VTEC. Unless it is chipped to do otherwise. It would be wise to use the right ecu! It would run better because the fuel maps are set correctly for the motor that its supposed to be in!
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    p28's are fairly inexpensive too. i would sell that p61 for like 200 bucks or so and buy a p28
  6. Jeef
    Jeef NO MA'AM Moderator VIP
    I got my p28 for 30 bucks.
  7. pills_PMD
    New Albany, OH
    that's a sweet deal
  8. knowledge
    Beale AFB, CA
  9. B16teg
    B16teg Junior Member
    if you use that dohc ecu you are gonna mess something bad up so i would use the P28 and drive the car or if you want use the P61 and throw a rod
  10. pissedoffsol
    like i said before :worthy: :worthy:
