Knock Sensor
Discussion in 'HYBRID -> EG-EK / DC' started by skylineboy, Oct 27, 2003.
  1. skylineboy
    skylineboy Junior Member
    I have a 94 JDM GSR in a 93 civic si. I'm using a JDM ECU P72 but USDM engine harness. Will the JDM ECU look for the knock sensor?
  2. H22AdelSol
    H22AdelSol Senior Member
    san diego, california
    why dont u find the pinout and wire it into the ecu? its only one wire. thats what i did on my jdm h22 with my modified usa harness
  3. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Yes, all the VTEC equipped B series ECU's, USDM or JDM, will look for a knock sensor.
    You might want to find the correct forum for posting in about the EG chassis, as well.
    MOVED.
  4. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    yeah, you need the knock sensor to be wired in. Or after the motor warms up, it will throw a check engine light.
    Darin
