knock sensor
Discussion in 'Civic and CRX - EF' started by BIGP4LIFE, Feb 20, 2009.
  1. BIGP4LIFE
    BIGP4LIFE New Member
    Delaware
    im hookin up a d16 in my 91 crx and cant figure out where the knock sensor goes. where does it go and with that not bein hooked up would it cause it not to start?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    what kind of D16 do you have that has a knock sensor?
  3. BIGP4LIFE
    Delaware
    i have a d16 a6 bottom end with a d16 z6 head im switchin it from dpfi to mpfi and vtec and i cant find a knock sensor hook up but the jumper harness i bought for the swop is saying that i need to hook up a knock sensor so i didnt know where it would go or if i need to hook that wire up to somthin else to by pass or redirect the wire
  4. D16SiHatch
    D16SiHatch New Member
    the a6 block does not have a knock sensor and i dont think it even has a place to install one. and unless you are running an obd2 ecu you don't need one.
  5. BIGP4LIFE
    Delaware
    yea i figured it out tonight and finally got it runnin thanks for yalls inputs
    but i have another ? i got the car to run and the cam gear and belt side is in timing but the distrubtor side is not and where is it in timing and keeps the car running it wont bolt up to any of the ears so whts a solution to that? would it be safe to turn the cam gear so its a couple teeth back nd it work or will it be in the position to where the vales will be down when the piston is up and mess up the valves and motor?????
  6. mintoxik
    mintoxik Member
    Oceanside
    to see if your dizzy is right put your engine to TDC then the rotor should be pointing to the #1 sparkplug.
    and if your dizzy won't bolt up did you get the z6 dizzy?
    or maybe it is flipped 180 degrees?
  7. BIGP4LIFE
    Delaware
    its a 42 u distributor, which is what i have read to be the right distibutor, and all the ears will bolt up, just not in the position that it needs to be for the car to run right it seems. and if you flip the distibutor gear 180 degrees it doesnt seem to fit into the head right so idk. any other suggestions to any other distibutor that i might need?
  8. mintoxik
    mintoxik Member
    Oceanside
    did you try and move the dizzy cause maybe ur IGN. timing is off
    but you have the right dizzy and check to see if your sparkplug wires are in the right order
  9. BIGP4LIFE
    Delaware
    yea i have moved the dizzy and it is in timng but where it is now and in timing it wont bolt up to any of the ears on the head and all the plug wires are right so idk what to do ?????
