Knock sensor
Vetalik
I have a 96 dx hb and i put in a d16y8 ex engine for now and i havent wired the knock sensor is it really nessesary ??? and it weird i have an intake and my friend 94 d16z6 coupe has the same just an intake and he smokes my by a whole car,.???? any ideas
his car is lighter.
and without the knock sensor plugged in, you are throwing the ecu into loop mode, and thus killing the performance potential of the car.
d-series motors do not have a knock sensor. If your throwing a check eng light you need to pull codes to see what the problem is.
Incorrect. The Y8 had a knock sensor.
Proof:here
Anyhow, as pissedoffsol said, your are probobly in limp mode. You need to hook the sensor up.
