knock sensor
Discussion in 'General Tech and Maintenance' started by highperboi, Mar 16, 2004.
  1. highperboi
    highperboi Senior Member
    Alameda, California
    does anyone have any pictures of a knock sensor taken out of the engine ?
    also does anyone know if when the knock sensor is throwing a code does it limit the engine's performance in anyway?
    thanks
  2. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    It throws the ECU in open loop, which gives you retarded timing, richer a/f mixture, and ultimately less performance.
  3. 9sech22civic
    9sech22civic Senior Member
    quick way to check the sensor. hook up and check your timing, use a hammer and tap the block as your reading the timing. if the timing retards as your tapping then its working just fine.
