knock sensor
Discussion in 'HYBRID -> ED-EF / DA' started by cycloneb18c3, Mar 21, 2004.
  1. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    Hi- I was wondering if a b18a1 had a knock sensor? my old block I remember seeing a green plug threaded into the block? also what kind of plug/pin is required to attach a wire to it to run to the ecu? like is there a special connector from honda I need to get, or can I use some connector I already have? for b16a2.
