Wow, lots of arrogance about what does and doesn't work....
If there is no knock sensor board on the OEM ecu, it cannot and will not look for the knock sensor.
A p28 doesn't have the knock board, but don't use it for a 1.8 DOHC engine in its stock form, the fuel and timing maps are too weak for the bigger motor
As for VTEC working or not, if you have a VAFC or similar inline with the ecu, that defeats the stock programming from the ECU and the VAFC or other device triggers the VTEC to activate.
HTH
