knock sensor
Discussion in 'HYBRID -> ED-EF / DA' started by 1slowcrx, Aug 12, 2007.
  1. 1slowcrx
    1slowcrx New Member
    i have a 91 crx with a jdm b16a and the cpu is giveing code 7 and 23 and when i drive it it does not have any power and its cuts off like its not geting any gas could it be the knock sensor and were is it located at on the back of the block
  2. freak86
    freak86 New Member
    Southwest Michigan
    it's pretty much right smack in the center of the upper portion of the block if i remember correctly from doing my swap wiring. try searching for swap wiring pics. i know they're out there. that's how i found mine.
