knocking noise
Discussion in 'General Tech and Maintenance' started by 97gsr, Jan 1, 2003.
  1. 97gsr
    97gsr Junior Member
    Ok this is odd....When accelerating at RPM's above 4000 my 97 gsr makes a barely noticeable knocking sound, and a more noticable pulsation in the gas pedal. This only happens maybe half the time and only when the engine is warm. Any suggestions on what could be wrong?....thanks.
  2. Jdm Delsol02
    Jdm Delsol02 Junior Member
    :blink: Sounds like to me the rods are knockin, LOL! Naw i don't know whats wrong, i suggest to go get it checked! and by the way turbocharge that $H*T and throw in some other mods!
  3. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    Might be cheap gas.
  4. chevy302dz
    chevy302dz Senior Member
    If it happens when you rev the engine while you are in netural then it is the bottom end. If it only occurs while under a load, then the engine is running lean or to low a octane gas is being used.
