Andrew
Active Member
Do any of you know what this Knuckle came off of? I know it is common to do EX/Si or DA knuckle/brakes. Top is the random one from the already swapped car. bottom is the stock DX. The swapped knuckle has a 10" 1/8 rotor (might not be the right measurement I forget exactly what it was.
10.3"
What exactly are you asking?
I don't know of any good ways to determine what kind of knuckle you have, but if the car drives straight you don't need to worry about it. Especially when you already have the "big brake" upgrade!
Are you planning on swapping this susp. setup onto the grey civic?
