Korax's ED6
Discussion in 'Auto Multi-Media' started by Korax, Jun 14, 2011.
  1. Korax
    Korax New Member
    Western PA
    It's been a while since I posted anything on my gray hatch. Figured I'd throw a few pics up and where I'm at on this particular car. This car was originally a 91 DX automatic.
    Electrical:
    Password JDM carbon battery relocate box with Odyssey battery
    Full 90/91 DX manual cabin harness swap
    Monotech custom Engine Harness
    White face gauges with LED backlights (temp before AP1 cluster swap stole from another hatch of mine)
    Timex LED tachometer (temp same as above)
    OBD0 PW0 ECU (chipped. no idea what. runs rich as hell and can't wait to get this thing tuned right)
    Power plant/trans:
    OBD0 B16a (stock)
    Password JDM carbon EG/EK B series intake
    USDM 92-93 GSR cable trans
    Exedy 9.5lb flywheel
    Hasport mounts
    Apexi WS2 catback
    Brakes/suspension:
    K-sport Rear LCAs (should have went with buddy club or something)
    93 EG Si Rear trailing arms/calipers
    90-93 DA e-brake cables
    Mugen rear trailing arm bushings (can't get new ones from Honda and I wanted a compliant bushing)
    Beaks* tie bar
    40/40 prop valve
    Intergra 1" non ABS master cyl/booster (don't remember from what year)
    Goodridge SS brake lines
    Rota group N with Kuhmo AST 195/50/15 (not great tires but I got the set for under $200 :ph34r:)
    ES poly front LCA and radius rod bushings.
    Hardrace front camber kit
    Body:
    Civic SiR fenders/stanley sidemarkers
    Civic SiR stanley clear corners
    Honda antenna delete
    Other/misc changes:
    Non-power steering with power steering rack
    89 gas tank (had one laying around and it needed one)
    No heating/A/C components (nothing under the dash at all)
    Have but not installed yet:
    DA front knuckles/calipers
    Hawk HPS for DA front calipers/EG rear calipers
    DC GSR camshafts
    Full set of new style Honda LMAs
    Car sound high flow cat
    S2K start button and an OEM clip
    Looking forward to:
    Progress suspension coilovers (getting the cheap ones as this car gets no miles and will go with something better once I know what it is I want)
    Progress suspension rear sway bar or OEM ED Si rear sway, haven't decided
    Center roll adjusters of some kind
    ESP traction bar
    Enkie RPF1's with Dunlop star specs
    Nascar cage (can't say if it will be in this chasis or not)
    AP1 Cluster and needed parts
    Cut off switch
    Chargespeed rear spoiler
    Probably a bunch of stuff I'm forgetting.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Nice! I want your hatch so I can cut the roof off. :)
  3. Korax
    Korax New Member
    Western PA
    :eek: What do you want to cut the roof off for?
  4. phunky.buddha
  5. E_SolSi
    EF pickup truck ???
  6. Korax
    Korax New Member
    Western PA
    Heh, well if you weren't in TX I have a roof or two you could have. I'm trying to cut up another hatch I have for scrap in the next few weeks.
    Edit: I'm retarded, you want the whole thing :x
  7. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Then you could really ride in style with a Ef pickup truck. Total chick magnet.
  8. phunky.buddha
    Nah, something else.
    Yeah, would want the whole thing. Ideally start with a CRX, but I might go with an EF hatch or a del Sol.
  9. Korax
    Korax New Member
    Western PA
    Hmmm, sounds interesting.
  10. TurboRex90
    TurboRex90 Golden EG
    Maryland
    i smell a potential epic build thread?
  11. phunky.buddha
    :D
    Well, anything I build now doesn't get posted until it's done.
  12. TurboRex90
    Maryland
  13. phunky.buddha
    Don't want people to copy new ideas. :)
    But back to Korax!
  14. Korax
    Korax New Member
    Western PA
    Got some ES bushings in the mail yesterday. All the bushings in the back have been replaced (rear compensator arms, LCA, Trailing arm bushings) so I ordered some for the front because they are most definitely 20-21 years old.
    -16.8102G Shock mount bushing kit
    -16.7102G Honda strut rod set (I always though these were called radius rods?)
    -16.3103G Honda front control arm bushing set
    The only thing left would be the front sway bar bushings. Until I get a coilover suspension I'm not going to bother with these. I'm not sure if I'm going to end up changing sizes or if I'm going keep the OEM bar, so no sense in doing it right now.
    I'm also going to install the beaks bar I bought awhile ago, assuming it quits raining this evening. If not, I'm probably going to do the work Sunday?
  15. Korax
    Korax New Member
    Western PA
    Got home after work today and had just enough time to throw the tie bar on. Working around my big exhaust canister was a paint in the ass. I like how quiet it is so I guess it's a trade off :x The jack makes it easy under the control arm. You loosen the 14mm bolt and slide it out until it gets bound. Then just slowly push the LCA up until the bolt literally falls out. Hopefully I'll get to the bushings tomorrow.
    I'm also having a problem with my signals. The hazards work fine. All six markers work, both indicators flash on the cluster. If I hit left or right on the column it does nothing:( I have switched out the relay from one of my working hatches, sanded all the related grounds. The one under plastic on the hatch/both of the ground clusters (for lack of better term) behind the headlights. I"m guessing I'm gonna have to change the arm out for a known working one. Is there something else I'm missing?
  16. Korax
    Korax New Member
    Western PA
    Been bad on updates.
    I figured out my turn signal problem. I had also had problems with my fuel gauge not working and the temp gauge. After checking fuses, grounds, connectors, relays, and switching arms from another car.... nothing worked. I did some research and found out about this little box on the back of the cabin fuse box. It's gray and clips in with just one connector. The ICU (integrated control unit). I never realized this little thing controls all sorts of things, signals, gauges, back up lights, wipers, etc. I switched it out for another from another car and everything works now. These little boxes are also stamped with A or B. Either will work to make almost everything function. The B box has the capability of intermittent wipers as the A box will only work with Hi and Low. If your ED civic doesn't have intermittent wipers you can just switch out the switch arm for one that does and pop in a B box and they will work. Pretty cool I thought.
    I did get the poly bushings done and installed on the front but I didn't get any pics. I did get a camber kit installed in anticipation of getting my coilovers that are on back order and got the car properly aligned. The kit is from Hardrace. Hopefully it doesn't turn out to be junk. It seems very heavy duty though.
    I also picked up a set of 18x7.5 17lb wheels for my tsx for $500. They have some minor curb rash and will be easy to fix. No bends/dents. They didn't come with caps, stems, lugs. Since all of this needs done I'm going to pick up hardware for the alternate bronze color these came in and have them done that color when they are fixed.
  17. Korax
    Korax New Member
    Western PA
    Got a few pics of the ICU in case anyone might need to know sometime. As you can see this is a B unit.
