L1H1 wire colors
Discussion in 'Civic and del Sol - EG and EK' started by hunterhound, Nov 9, 2009.
  1. hunterhound
    hunterhound New Member
    Trying to find out what the 5 wires on the L1H1 NTK O2 sensor are for, such as which ones are heaters, etc. The colors on my sensor are:
    White
    Yellow
    Orange
    Red
    Black
    This was an engine swap, from obdo to obd1, with a conversion harness and now I need to get the O2 connected to a PO7 ecu which I just obtained. No plugs or harnesses available to me, just wanted to know what the colors on the actual sensor side were for and then I could find the proper pinout on the ecu.
  2. hunterhound
    Got this from NGK
    Yellow: Heater Ground (-)
    Orange: Heater Power (+)
    Black: Common Ground ( for IP and Vs )
    White: IP circuit (Current pumping) (+)
    Red: Vs reference (+)
    Now, could anyone guide me to which pins these would go on the PO7 ecu?
  3. BrutalB83
    Rochester Hills, MI
    This belongs in the EG/EK section, so I'm moving it there...
