Launching
Discussion in 'Racing and Driving Techniques' started by 2fastaccord, Jan 21, 2003.
  1. 2fastaccord
    2fastaccord Senior Member
    Which method do you guys think works best? I hear some guys say they rev up to a certain RPM and then just dump the clutch. Others Rev way up there and come off of the clutch much slower and kind of feather it. Which do you use? What do you think is best?
    Peace*
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    It all depends on your set up. With me, my clutch sucks, on its way out and i wont put one on until its for the ITR swap. With a stock clutch, feathering it is a little harder on it but wheel spin can be eliminated. With me, I rev to about 2.5-3.5k rpms, dump the clutch, and kinda slowly press the gas in, other wise i get too much wheel spin. If I had good suspention i would probally be offering you diffrent advice
  3. 2fastaccord
    How much wheelspin do you usually have when you dump from like 3k?
    Peace*
  4. asmallsol
    it depends, true not much, but once you start to spin, it is hard to stop (coeffecint of friction is reduced)
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah i do it alot like asmallsol does... i had a act stage 2 and i'd dump it at 2200-2500 and it'd hook up (like a b16 has the power to spin at 2500 anyways) but that always worked pretty good.
  6. micah
    micah Senior Member
    panama city beach, florida
    depending on how good my tires are determines where i dump at.
    with the paradas i have now(about 500 miles on them) i dump at about 6. that might sound like alot but my friend dumps his sol at 3 and i smoke him off the line everytime, same motor, but he has more work done.
    wheelspin is not a bad thing in a car whos peak power is at 7200, dump too soon and your wheels will catch way before your powerband. dumping at 6 by the time my wheels catch im high enough in the rpms, that vtec engages off the line and im off. you just have to be able to control your wheelspin. with 14's and old tires i dumped at about 3.5-4, dumping at 6 or higher on them and id bark 4th :)
  7. pissedoffsol
    dumping it is good if you have slicks... thats about it.
    ride it a little bit- i bet you go faster
  8. cxjon
    cxjon Senior Member
    man+k+toe
    i do what b does or said it works better for me... i dump to do burn outs
  9. asmallsol
    But if your like be that has a shitty clutch and does not want to shell 2-300 on a shitty d-series for a clutch, your going to dump the clutch and just "feather" the gas to prevent wheel spin
  10. ludeconduct
    ludeconduct Senior Member
    Near Sac CA
    My theory is a lttle different, if you dump the clutch it doesn't spin on the flywheel that much and won't heat up like it will if you feather it. Once your clutch is hot, you won't get a clean shift into any of the other gears, therefore not providing the maximum amount of horse to the wheel. Your clutch will just spin for a few seconds. Basically, when you heat up your clutch, it acts like an old worn clutch and we all know we can run better times with a new clutch. I dunno, just my two cents.
  11. vtecnitrocrx
    vtecnitrocrx Junior Member
    rev around 5000 and feather it to reduce wheelspin. When runnin a torqueless motor, any lower there is no torque to even speak of. The key here is to keep within the higher edge of the powerband and not bog. Keep in mind I lauch like this with a stock clutch and a 70 shot on tap. This is by far the best method as every Sat all summer I experimented.
  12. wildbillhatchbac
    wildbillhatchbac the OG VIP
    werd. . .. droppin the cluch = smokey rubber burnin fun
    riding the clutch = better lauch, less wheel spin
  13. cxjon
    cxjon Senior Member
    man+k+toe
    speaking of burnouts for fun... a week ago i was leaving a bar with my friends in the cx and as we were driving out a dumb mother fucker stands right out in front of me and would not move... so i got a dumb idea of doing a burn out to scare the mofo so he would move.... i pulled up the ebrake reved up real high and dumbed that mother fucker... the dude freaked out and moved fast like ... i kept it going for a few seconds and let of t e and drove away.... it was a real smoky burn out and i was proud of it :D
  14. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    were you drinking and driving?
  15. pissedoffsol
    its a cx. he could probably walk home faster :)
  16. jdmcrx89
    jdmcrx89 Senior Member
    AL
    heres my 2 cents, nothing proven or scientific about it, just how i do it
    i have 2 ways to launch
    car is a 89 crx si, d16a6 motor, coilovers, 15 in wheels with federals (cheap ass tires)
    stock clutch
    either i
    a: rev up 2 2000, dump the clutch and spin out a bit then grab
    b:rev up to 3500 ride the clutch and eliminate most of the spin
    when i track race or race on really good roads i use method A
    when i street race or race on roads not really good for racing like roads with dirt or old gravel ect i use method b
    also i agree when the clutch gets too hot it slips, mine does it all the time.
    who here has a b16a sir? with a upgraded clutch? what do u launch at?
    why i ask is because im swapin one in.
  17. theorangeCivi
    theorangeCivi Junior Member
    It is always going to depend on a few factors no one can say what is right cause no 2 cars are exact... you have to know your car.. biggest factors are weight of car, clutch, tires, and your engine.. it is something you need to figure out yourself. go out and lay down some rubber and find out what is best do it over and over cause practice makes perfect
  18. artosarijt
    artosarijt Member
    silverdale , WA
    to properly launch by dumping you do need slicks or 18's. Sit in an empty parking lot and just practice in all differents ways to see what your car does best at. Expirement for yourself with riding the clutch, feather the gas whatever.
  19. JrSiRb16A
    JrSiRb16A Senior Member
    Daytona Beach, FL
    ive got a B16a with a shitty ass stock clutch..and if i dump at 3000 ill spin for days..but ive never tried it at the track yet..so i really dont know what method is gonna work for me..i jus know i cant wait till i upgrade my clutch..not yet..i still lots of work to do first..
  20. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    funny... only time i get traction on the launch is if i launch like im just driving off from a stop sign, but then all that traction stuff comes to a hault when vtec kicks in ::shrug:: lol but what do i know... PLUS when i had slicks on at the track i STILL didnt get traction, and thats launching at 2500-3k... hopefully a zex flywheel will help me out!
    Zac
