jomarlin123
K-5eRiEs Is ThE 5HiT.....
yea it done it on all the dvds, but it also only does it while im using the hdmi cables, when i use the the normal audio video cables its fine,.so do i need to take the tv back or the dvd player
Ok this is the last thing you should check if you have another hdmi cable try it out if it still does the same then is the Tv maybe the hdmi input are bad try that last thing if it dont work i recomend that you send it back .
