Leaf Blower makes 10whp on an Si!
Discussion in 'Auto Multi-Media' started by civicious, Sep 2, 2005.
  1. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  2. Celerity
    Celerity Well-Known Member
    What an awesome way to get an idea of what your car will look like with either boost or Nitrous. Rednecks +1
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    OMG..Thats so fu*king funny....Bahahahhaa...WHat a tard....But hey It worked...HOME DEPOT here i come.....lol
  4. Dustin_m
    Dustin_m Active Member
    San Diego, CA
    Isn't that about the same thing as running your intake tubing into the AC blower? I know that was an old hot rodder trick, and i am probably gonna do that on my 69 chevy.
  5. civicious
    Houston, TX
    Wouldn't you actually lose hp running your intake to your AC, seeing as your motor uses hp to power the compressor?
    And a leaf blower blows a LOT harder than an ac fan...
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    I always figured you could get a couple of extra horses out of a leaf blower. That sucks that its been made public.. I'm going to be running with some jackass and hear wooooeeeeeeeeeeeeaeaeaeaeaeaeaeaeaeae and he's gonna start pulling on me.
  7. Cashizslick
    Haha, who knows? Maybe this will be the next big ricer mod . . . pull your a/c and rig a toggle switch to a leaf blower mounted in the front of your car . . . . .
  8. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    This is the same principle as those 69 dollar universal "electric superchargers".
  9. n20hatch
    n20hatch Member
    Oregon
    I'd be kinda freaked that somthin would blow up in my face doing what their doing lol.
  10. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Leafblower > Ebay blower. Ebay blowers are basically the same motors that are found on your A/C or heat blower. Usually 1/8th, or 3/8 hp electrimotors. You're lucky to see 40mph out of them. Big, bad leaf blowers usually can push 200mph (gasoline versions), or slightly less for the electric versions. This is partially due to a better impeller (impeller vs. fan), and better gearing.
    HoMe DePoT SpEeD!!!11one
  11. E-dogg
    E-dogg Senior Member
    So how would you rig it so that you could have the leaf blower at full power all the time,or at full power when you accelerate/want it. That would be the trick. I imagine if you had it at full power all the time it would burn the leaf blower up pretty quickly. Also, would it be possible to change the exhast somehow to add to the "turbo/supercharger" benefit. Just curious. If you could get an electric leaf blower, get it to run off your cars electrical system, and shorten the tubing to allow the leaf blower to sit in your engine bay.... I suppose you could have it run all the time if you wanted it too. I would think it would be kind of loud and would probably get pretty hot.
    How about this..... Hook a toggle switch up, as someone stated already, to have the electric leaf blower start up when you want it too. A gas powered one is out of the question. It seems you could only start one manually, and if you could find one with a push button start, having to stop and put gas in your leaf blower is just too ghetto even for me. To get the leaf blower to rev you could hook up a wire, perhaps similar to a hood release cable?? and have it connect around the "trigger" of the blower so that when you pull it up it could be locked into place and then released when done. I think you might wear the cable out quickly from lots of use but if you can find some material that is cheap and an easy way to run it besides under the fender this could be an extremely cheap upgrade to a car.... ghetto yes but hey, it's still 10 hp alone. With the Nos it was an even more impressive upgrade imo. Might try this on my delivery car just out of curiousity. If I do Ill get it dyno'd before and after and post pics.
  12. Cashizslick
    Just tap a line into some part of your fuel system: gas tank, fuel lines, etc. B)
  13. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    yea but at $3.40 a gallon, i'm not wasting my money blowing gas powered leaf-blower air into my intake.
    You will need a power inverter with an extremely high amp rating, we did this 3 years ago with my buddies 99 civic and my 89 prelude, the acceleration was great, but we ran out of extension cord... and yes i am dead serious :ph34r:
    If you get a power inverter that can handle the draw that the leafblower uses, it will work... if not, you will keep blowing fuses.
    If you do find a cheap inverter that you know will handle the draw, let me know. i'll go to goodwill and get a lead blower for $3, buy the inverter and i will take it to the track.
    My problem wasn't finding the inverter to carry the load, but they were all like $250 back then.. ebay here i come B)
  14. GSRCRXsi
    MD
    most leaf blowers are 2 cycle engines. you wouldnt be able to just tap into the fuel line. it needs a gas/oil mix.
    but i dont even know why we are discussing this, its a dumb idea to try to make a permanent mod out of this.
  15. phyregod
    phyregod !!YTINASNI
    Central Texas
    Seriously, are they really getting 40mph out of those things? This might be a nice mod to the A/C system in my car. I'm going to have to look into that.. Performance A/C.. Instead of my stock .0000012mph blower.
  16. Battle Pope
    Go down to a marine supply place and get a bilge pump. Yes, a bilge pump.
  17. E-dogg
    What if you hooked up a circuit breaker in your car instead of a fuse?? I had a friend do that when he was running two 2000 watt amps. Kept blowing fuses left and right so he hooked a circuit breaker up.
  18. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Lets keep one thing in mind, that power gain was sticking it to the intake tube, no filter. I doubt you'd make that much horsepower but actually mounting a leafblower in your car. It would HAVE to run through a filter or your motor will not last. Also when the leaf blower is not on your going to have to pull air through the leafblower which is going to kill your power.
    :shrug: maybe have a temp hookup for the strip, but full time, nah
  19. E-dogg
  20. old Skuul Hatch
    old Skuul Hatch Senior Member
    Honesdale Pennsylvania / Fort Smith Arkansas
    forcing more air and adding nos = lean
