Leaking Trunk
Discussion in 'General Tech and Maintenance' started by wanderinman, Mar 21, 2005.
  1. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    1996 LS sedan
    Ok, my trunk RANDOMLY started leaking the other day (ok, about 6 months ago, I'm just getting around to dealing with it). I think the water is coming in from behind the tail lights, but I can't figure out a reason for it to have started leaking. Has anyone else had this problem? If so, how did you fix it, I was planning on getting some expansion foam and sealing the back tail lights. I've already lost my carpet on the bottom and my cardboard flooring to mold, and its getting worse.
  2. CrazyAzn
    CrazyAzn Senior Member
    i had that problem, but that was on my 90 hatchback, it turned out the rain gutter that ran drained down went straight to were my tail lights are. so they water was gettin in between the tail light and the body, basically to fix that i used some weather seal stuff, basically silicon to seal off the tail lights (tail lights to the body) and woosh, problem fixed.
    on another note i had a 92 lx sedan but didnt have that probklem i had more along the lines of a leaking passager floor, but a stupid ass driver fixed that headache when he hit me on the way to school, and bought me my hatchback. fun stuff but a sad ending to a good car.
    i dont noe if that helps at all, but mine was leaking from between the tail light and the body.
  3. wanderinman
    Raleigh, NC
    Yea, thats exactly what I was thinking it was, I'll go to wal-mart and seal that bitch up later on today. Thanks
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    my 98 fodo leaked. i replaced all the seals and stuff and it still leaked. never figured out how/why. my spare tire well would fill up with water whenever it rained. i just drilled a buncha holes on the bottom of the spare tire well so the water would drain out.
  5. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    do you still have the foam on the tail lights that seal out water
  6. wanderinman
    Raleigh, NC
    There's about a 1/4" gap between the lights and the body, and it doesn't look like there was ever any foam. Its not so much that it is leaking, cuz that I can fix, I am just pissed I can't figure out why it started (I'm a dork like that, I dont enjoy when things with no brains outsmart me, lol)
  7. TWISTEDIMAGE
    CASPER WYOMING
    the tail lights should have about 1/8 inch thick peice of foam between the light and the body
  8. wanderinman
    Raleigh, NC
  9. civicious
    Houston, TX
    yeah, you should have a foam piece there
