Pictures and descriptions, even though some of you could care less. Well I could care less about you caring less. so ha!
Anyway, I decided to rip it down to the base and redo it removing 4 blocks from each side of the perimeter, I had initially designed a 26x26 brick building, but I shortened it to 22x22 so each "column" piece would only be a 1x1 brick instead of a 2x1 or 2x2 brick. This will help to simplify the pieces I'd need to order once I went through all my moms pieces.
I went over to my moms right around 4:30, helped her shovel some and then went in to demolish and reconstruct. I came up with a few new things that I added into the building as well.
Here's the building redone, With my internal bracing worked out as well. It'll be stronger since one piece will connect to the inner bracing, and then back to the opposite wall.
^ (wow you can tell which is the old window piece in this picture... I'll have to move that elsewhere...)
In this one you can make out the elevator shaft I'm building into it for the skylobby. You can also see all my plates supplies in front there.
In this one you can see the full elevator shaft rising. The bracing will be done every 10 floors. The elevator right here reaches right around the 50th floor mark, in case you're wondering. This is right around where the first set of stepbacks will occur.
Kind of a shitty picture, but this is the skylobby entrance.
Here is the skylobby floor. I built it into the design so that the elevator shaft will end right there, I'm also going to build it so that you can take off the top 5 floors and view inside the skylobby.
After resizing the entire building, I had to redo the roof as well. I think it turned out awesome. I redid the antennae so that they're in the triangular shape the real ones are.
In case you're wondering, this was my brothers old room from the early 90s until he moved out, he draws, paints and yada yada so they let him draw and paint his walls.
