K2e2vin
Originally posted by WhItE90CRX@Apr 10 2003, 08:25 PM
Adding a lighter flywheel does not add any hp (if it does it is very minimal no where near it feels) at all it does help out acceleration tho .... lets just say for instance you have a rwd car and you have lets say 3.31 gears in the rear end and you put 4.11 gears in there you gain acceleration but you dont gain any hp.... you def get a huge gain in acceleration tho.
you will gain hp b/c heavy flywheel uses some torque to spin it, and hp=measure of torque at a rpm. use a lighter flywheel then youll have some torque that was loss at the flywheel go to the wheels. if you know how pulleys increase power, then youll know the lighter flywheel is the same concept; decrease power loss. but the lighter flywheel would store less energy, so when trying to cruise youll use up more fuel b/c engine has to keep the car moving.
