lightening a flywheel
Discussion in 'Engine Building' started by Sergey P.A., Feb 28, 2004.
  1. Sergey P.A.
    Sergey P.A. Senior Member
    253 Tacoma
    ok, what are the benefits in terms of performance to lighten you flywheel, and I am not just talking about weight difference, because obviosly it should be a power difference too, can somebody explain it to me?
  2. E_SolSi
    no real power "gain"
    but you will get more to the wheels due to less drivetrain loss (similar to what happens when you use light weight rims)
    acceleration and RPMs are quicker
    but the throttle becomes a lot more "touchy" (slight variations are felt a lot more)
  3. jamesA
    Less rotational mass, it'll allow the engine to spin more freely allowing it to do less work, this is also good on gas mileage and extends the life of the engine.
    Balancing the rotating assembly and using light weight components will help the engine even more. When you get on it, the engine will rev out faster and easier than it's ever done before, the only downside is when you let off the gas to slow down, the revs will drop faster as well.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    your freeing up power that was normally robbed under heavy weight.
    recommend getting a new aftermarket flywheel, such as either fidanza/act/etc...
  5. Sergey P.A.
    253 Tacoma
    thanks people, I appreciate the Info.
  6. JDMilan
    Boca Raton, FL
