'Lights on' warning - not working. ???
Discussion in 'Civic and del Sol - EG and EK' started by Kurious, Jan 31, 2011.
  1. Kurious
    Kurious New Member
    The warning sound that used to inform me if parking/headlights were left on is no longer working. Guess what? Battery was dead this morning as parking lights were left on. I had someone work on my wiper motor and I found a couple fuses on the floor or my car. I think they pulled some when fiddling with the repair. I should have gone right back, but didn't. Is this a simple fuse issue? Can someone tell which fuse I can check? The manual is doesn't list one specifically for the warning. Thanks in advance. It's a '98 Civic DX.
  2. E_SolSi
    check the drivers side door pin switch
  3. Ichigo1174
    Ichigo1174 Member
    Florence, SC
    I had this same problem in my 94 Civic LX except sometimes it would chime. But I wasn't missing any fuses. it doesn't so it at all anymore. I've learned to check them every time I walk away from the car and I just carry jumper cables. ^_^
