limp mode
Discussion in 'HYBRID -> BA-BB /CA-CD' started by white lude, Nov 12, 2004.
  1. white lude
    white lude Member
    Aight guys quick question for ya. I swaped a h22 into my h23 lude (93) got it running before i hooked up the downpipe and o2 sensor. now that its hooked up it still runs the same. Is it still running in limp mode? Theres no check engine light anymore. How do I turn limp mode off? Its running really rich and has about 30 hp. :huh: if not for limp mode what could it be? Advice would be greatly apppreciated.
  2. white lude
    white lude Member
    someones gottta know how to do this
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    Limp mode is in the ECU, but you are not in limp mode if you don't have an engine light on.
    To reset the ECU, pull the fuse for the ECU or disconnect the battery for 15 seconds. If you disconnect the battery, make sure it doesn't conflict with an alarm system or radio to do so.
    Do you have a P13, or are you using the P14 still?
  4. white lude
    white lude Member
    Yea, Im going to hookup the new ecu today( Just got it in). Hopefully it has different fuel maps to change the way its running . Besides that I think the only other thing it could be is timing. :( <_< hmmmm i hope i didnt bend a valve or somethin. :angry:
