list for d15b vtec swap in 92 civic lx
Discussion in 'HYBRID -> EG-EK / DC' started by 92civy, Sep 10, 2006.
  1. 92civy
    92civy New Member
    this is what i think i need:
    JDM d15b vtec
    92-95 ex/si engine wiring harness
    p28 ecu
    spark plugs
    oil
    filter
    valve cover gasket
    head gasket
    what else should i get or do
  2. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Look at getting an EX/Si header if you don't already have one. Additionally, change the oil pan gasket and do the timing belt and water pump while the engine is out. Other than that, I think that list covers it.Just take some extra time and clean the motor.:thumbsup:
  3. 92civy
    92civy New Member
    what timing belt and water pump i think the vx belt works right but also the water pump i heard that i should use ex/si(d16z6) parts for tyhe block and then use vx parts for the head is this true
    also what oil pan gasket
  4. Madcow
    Madcow New Member
    The waterpump for a vx or si will work, the vx timing belt will work, it has to be 103 teeth. I got a great deal on ebay for the complete D15B engine gasket set.
  5. 92civy
    92civy New Member
  6. Madcow
    Madcow New Member
    Yep $100 is a good deal, i paid $85 just for my waterpump
