I started reading up on turbo and it seams to be tricky. I can’t afford to blow my motor. I drive it every day to work. So I’m thinking of going with an all motor set up that way I can build it one piece at a time and NOT blow my shit up.
Below is a list of what I was going to start working toward. What I would like to know is “don’t need it†“get this instead†and “you really should do this alsoâ€
Following the air
______________
Cold Air intake (got it)
Throttle body (? Don’t think I need)
Skunk2 Intake manifold($250)
Skunk2 Stage 1 Cams($300)
Adjustable Cam gears($100)
4-2-1 header (?or 4 to 2)($200)
High flow cat($50)
2.5 mid pipe w/high flow exhaust(got it)
Following fuel
____________
fuel should be fine(I guess)
Following spark
_____________
(open for suggestions on spark)
Suspension and handling and Misc.
______________________________
Taciko blues(got it)
Ground control coilovers w/ tender springs in rear(got it)
22mm rear sway bar($150)
shock tower braces all the way around($75)
camber kit all the way around($175)
15 inch aluminum wheels (integra)(got it)
drilled break rotors(200)
front air dam($150)
Short shifter(I have one but I snapped of the threads, cheap POS)($100)
LSD($350)
Clutch(????)
Flywheel(???)
ECU(I guess hondata, the programmable one)
I know I could go a lot farther but this seems like something I could do 1 to 2 years($) and get speed increases along the way.(also prices are rough guestmits on good deals and used parts)
Im going start on the following air flow first.
My Currant setup
90 crx si
b16a1
currant mods are shown in list above
(want to keep it a sleeper)
0 weight reduction, nice leather seats and a quality system, (w/AC OOO-YEEAA)-------Florida
Following the air
______________
High flow cat($50)
Following fuel
____________
Following spark
_____________
front air dam($150)
LSD($350)
Clutch(????)
Flywheel(???)
My Currant setup
90 crx si
b16a1
