Little D14A
Discussion in 'HYBRID -> EG-EK / DC' started by EK-9, Mar 1, 2008.
  1. EK-9
    EK-9 New Member
    I have just picked up a 1400cc Honda Civic 98reg I think the chassis/model no. is EJ9 it has the D14A engine its a great little run around but needs more power. Now I have read that a mini me swap can be carried out on any D series engine?? Would you recommend this or should I swap the whole engine? Are the wiring looms much different? Any suggestions from you guys on what I should do to get more hp would be great!!
  2. solobomber
    solobomber New Member
    if you do the mini me swap youll want more power i say go with a b series motor good power
  3. H22juggsEG
    H22juggsEG New Member
    first thing these guys wanna know is your budget how much u willing to throw down on power. are u gonna race or it's your dd.?
  4. EK-9
    EK-9 New Member
    Its just my dd really but I wanna put a few bits on it and I have a set of 17" wheels to go on and I just think it will put alot of strain on this small engine so wanna change it I would be interested in a mini swap maybe as its cheap:D
  5. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Just swap in a d16z6. Much easier/cheaper and it will haul you and your 17's without a problem.
  6. EK-9
    EK-9 New Member
    And would it be best/easiest to just get rid of my old wiring loom and use one from a civic d16z6 as my car has only a dual point injection and there multi point
  7. formby
    formby learning in progress
    get the harness/ecu from a same year car that came with the d16 engine.
  8. sevenhillsbilly
    sevenhillsbilly New Member
    yeah and if you want more power just get the mpfi but you need the harness and maybe a vtec head if you want even more but then you have to get a diffrnt ecu as well
