little stuff i can do to my h23 to make it quicker?
Discussion in 'Prelude' started by ct989, Jan 16, 2009.
  1. ct989
    ct989 New Member
    pennsylvania
    besides cold air, exhaust, and timing advancement. i just need some little upgrades that won't run my wallet to hell
  2. austin20110
    austin20110 New Member
    Northern Va
    N2o
  3. ct989
    ct989 New Member
    pennsylvania
    what kind of internals are required for that? i'm guessing pistons and arms. anything else?
  4. austin20110
    Northern Va
    depends how much you want to spray.... maybe some rods and pistons.... all depending on how may passes you want this to make
    and btw
    why did you advance your timing?????
    and how much did you advance it???????????
    1 person likes this.
  5. ct989
    ct989 New Member
    pennsylvania
    more low end power. i tilted the distributor about an inch. it made a good difference. it goes pretty good off the line.
  6. nootrac22
    exeter pa
    don't fuck with the timing unless there's a need. engines are timed because there is a need, so only adjust the timing if there is a need.
  7. ct989
    ct989 New Member
    pennsylvania
    its not knocking or anything, it seems to be ok
  8. nootrac22
    exeter pa
    it's supposed to be timed properly, end of story.
  9. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    You need to set the timing back to normal! A cars timing is supose to be spot on, not half an inch forword because you think it gains power. It dose not! If you inproperly set the timing it could cause serious engine damage!
  10. serrilion
    serrilion In my own little world! VIP
    Vermont
    I hear shavings in the oil pan soon! EEK!
  11. serrilion
    Vermont
    BTW to answer your question, in my opion besides fix the timing, Looking into Pullys, they can free up a little HP, and they arn't to badly priced eather and simple to install :)
  12. ct989
    ct989 New Member
    pennsylvania
    alright i put it back to the stock setting. i had it marked so i knew where it was originally.
  13. 97hatch
    97hatch ?
    Anderson IN
    wow if you have a car that requires 87 octane fuel and you fill it with 93 octane it would benifet the engine to increse the timing as 93 burns slower and has a better detonation resistance and runing the timing more advanced also makes more power because of where the piston is at in the stroke
  14. ct989
    ct989 New Member
    pennsylvania
    i run premium in it already, but thanks
  15. 97hatch
    97hatch ?
    Anderson IN
    with premium fuel it will make more HP with that timing advanced which would be pushing it toward the firewall if you retard the timing it will make more tq which is what youwere doning before thats why it felt better down low
  16. ct989
    ct989 New Member
    pennsylvania
    alright. yeah thats what i knew i was doing anyway. i knew it was only more torque in lower gears. i just reset it back to the stock setting because everyone told me i was gonna blow my car up haha.
  17. Ethan
    Ethan Well-Known Member
    you've got a H23 in there right?
  18. serrilion
    Vermont
    The title say "little stuff i can do to my h23 to make it quicker?" Hehe :ph34r:
  19. ct989
    ct989 New Member
    pennsylvania
    haha. any more options let me know guys!
  20. Ethan
    lol who changed the title?
