1. B16A2/3: Completely bolt-in Swap, VTEC needs to be wired, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol
2. B18B: Completely bolt-in swap, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol
3. B17A: Completely bolt-in swap, cable-hydro transmission kit(not recommended) or hydraulic b-series transmission, VTEC needs to be wired.
4. B18C1: Completely bolt-in swap, VTEC needs to be wired.
5. B18C5: Completely bolt-in swap, OBD conversion, VTEC needs to be wired.
6. B16B: Completely bolt-in swap, OBD conversion, VTEC needs to be wired.
7. H22A: Mount kit required, Hasport shift linkage, VTEC needs to be wired.
8. B16A: Not recommended! Too much work, more costly compared to B16A2/3's.
9. D16Z6: Completely bolt in, VTEC needs to be wired.
10. D16Y8: Completely bolt in, VTEC needs to be wired.
