lookin 4 sum answers
rudedawg2469
h22.....the 12 sec. high
jus bought a '92hb and i would like 2 kno wut all i need 4 a h22a swap, so plzz help out and let me kno........:confused:
first you should post in the EG forum.
this is an incomplete list, but for sure you will need:
H22 engine, tranny, ECU
shift linkage and mounts that fit your car and H22 swap (try Hasport)
different axles (not sure which ones though)
you will probably need to add some wires to your harness for the VTEC solenoid, knock sensor and O2 sensor. I had to do those for my B16.
that shoud get you started, ask a moderator to move your post to the EG forum or the swap forum and you will get the rest of the information you will need.
