Originally posted by MikeBergy@May 5 2004, 11:55 PM
It doesn't care if there is a small turbo or a giant one, psi is psi
Originally posted by MikeBergy@May 6 2004, 01:10 AM
I stand behind my remarks, if you are not operating within the peak efficiency of your turbo, you messed up on building your engine, and it's time to either lower your boost pressure, or get a bigger turbo.
Originally posted by MikeBergy@May 6 2004, 01:28 AM
Just because someone knows about a turbo does not make that person capable of engineering a capable system, modifying a system that was systematically designed by intelligent and informed engineers.
well, that is pretty much what the argument developed into; an argument about how to properly size a turbo. I am just saying that turbo size is irrelevant if the turbo you have can supply the pressure you need, at it's peak efficiency. You buy the turbo to meet your expectations, and if you buy a small one, thinking it will make huge power numbers, then you are off your rocker, not you personally, but just people in general. Just because someone knows about a turbo does not make that person capable of engineering a capable system, modifying a system that was systematically designed by intelligent and informed engineers.
Originally posted by ndogg@May 5 2004, 11:34 PM
lets say that you are pushing 15 psi on a straight t3 super 60. this may be at the upper end but still on the peak efficency island.
and i am using an sc61 at 15 psi, and this too is on the peak efficiency island.
if you believe that this scenario is possible... are you telling me that you think the motors will get the same power?
the answer is NO because the sc61 is flowing ALOT more CFMs at the same pressure. both are operating in the effeciency islands but the larger turbo flows MORE air at the same pressure level.
so once again... and this is the last time PSI is irrelevent, CFM is what matters.
Originally posted by Import Builders+-->Import Builders) said:all I have is one thing to say, because its obvious I can't change some people's minds on many topics.
You lack reading comprehension, or you're talking to the stunnas, bro. Everything I say is exactly what I mean... if you need clarification, I am more than happy to provide it, but I am entirely correct in my statements. I just want to make sure we are having the conversation I think we are having.
Originally posted by Import Builders+-->Import Builders) said:Whoever says, and I mean whoever...that using a smaller turbo and boosting more to make 300 WHP is better than using a larger turbo boosting less and making 300 WHP is better is flat out:
insane. and wrong. ( no offense guys)
I never said anything about turbo size. I was talking flow, case in point headflow, and how it affects boost pressure vs power output and their ties to engine longevity.
And the motor boosting higher is wearing more than the motor boosting less making THE SAME POWER>
BECAUSE:
It generates more HEAT. Heat causes wear, big time.
So I conclude, that a motor making 375 WHP with 10 PSI is wearing less and lasting longer than another motor making ONLY 300 WHP boosting 15 PSI.
(at the same compression level) we are talking about using the same pistons in both motors.
Lets level the playing field with your example, and say both engines are making 300 whp... the first engine at 10 psi, and the second engine at 15 psi. All else about the engines and their setups remaining equal as you stated; compression level, manifold selection, turbo selection, etc.
Now.
Walk us through the math that demonstrates how 5 psi extra intake pressure results in the adiabatic heating of intake charge that would result in a loss in engine longevity. Keep in mind every 7-10 deg F rise in temp is equivalent to losing a point of octane.
I really want to see the big difference in intake temps that's going to directly correlate to knock threshold and engine longevity. I'm waiting with bated breath.
The less boosted, more powerful motor is going to wear less.
Horseshit.
Its people that say otherwise that are really spreading misinformation. More pressure=more heat. more heat=more wear more wear=rebuild sooner.
I won't argue that more heat = wear and tear... that's common sense. I wholeheartedly argue that there is any *significant* increase in pressure/heat from the intake tract in the setup I have outlined above.
Now, stunna, let's look at the whole picture of what is going on here. You know, the shit you are missing? We're going back to your lopsided 375 whp @ 10 psi versus 300 whp @ 15 psi example you seem to think is relevant to anything.
The engine that is making more power, regardless of boost pressure, IS FLOWING MORE CFM.
This means MORE AIR IS ENTERING THE MORE POWERFUL ENGINE'S COMBUSTION CHAMBER.
You get a HELL OF A LOT more combustion chamber PRESSURE which means MORE HEAT off of the larger amount of fuel being burned in the 375 whp engine. The simple goddamn physics of the matter is that the 375 whp produces more heat-energy than the 300 whp engine does, which is why it makes more power. MORE HEAT EQUALS MORE WEAR - I AM AGREEING WITH YOU, YES?
I have not even mentioned the adiabatic heating the larger intake charge of the 375 whp engine undergoes on the compression stroke, due to the increased dynamic CR anbd cylinder filling associated with being a higher output setup, which is going to surpass the heating effects of the energy represented in the intake charge itself.
Import Builders@
more boost with same compression motor = more heat
Wrong. More power output is directly related to more heat. Read the above passages a second or third time if still confused.
Import Builders
With everything being equal, I believe this is a scientific fact.
