looking for H22a Turbo Base Map Crome P28 or even Hondata S300?
Discussion in 'Forced Induction' started by bbgambini, Aug 4, 2007.
  1. bbgambini
    bbgambini New Member
    looking for H22a Turbo Base Map Crome P28 or even Hondata S300? can someone send me one?
    The only options I've seen so far was supercharged H22a 550cc injectors for Hondata, and just stock spec H22a for crome and uberdata. I know there have been a bunch of people on here that have done this setup and have gotten a good tune, can you share your map?
  2. pissedoffsol
    make one your self, its not hard.
    go into crome.
    select the p30 preset and add boost tables
    do the .75 per lb ignition modifier
    plug in your injector size.
    remove check sum
    burn to chip.
    bam, basemap.
    jsut stay out of boost until you tune.
