Looking for some oppinions
Right now i have a 2000 honda civic sedan stock. I would like to do an engine swap and eventually boost in the future. I was wondering what engine would be more worth while, the b16a2 or the h22a?
and which would be cheaper because i think you need to put stiff shocks and springs on to handle the extta weight with the h22a.
thanks
if your just going boost then in the long run there both the same, i would just get the b16a or the b18b1
i think you need to put stiff shocks and springs on to handle the extta weight with the h22a. thanks
If you're thinking of swapping engines and boosting but stiffer shocks and springs aren't already on your list too...well...then you shouldn't be thinking of swapping engines and boosting...
