looking for stroker kits
I've did about 5 minutes of searchin thru honda-tech and what I have gathered... Is there really isn't a stroker kit out, or its not worth it...I hear you can use f23 crank and pistons but you only gain .1L and can't rev as high... your better off just building up your h22 its allready a big motor.
screw stroker kits. the h22 already has a long-ass stroke.
sleeve/bore the motor out 2-3mm more than stock, and go with a larger bore piston to match.
you'll make more power, keep the same honda geometry, and won't effect your rev-ability
