Loop Power Steering?
Can someone explain the procedure for this?
How do you loop the power steering and get rid of the pump and pulley?
For a Acura integra LS 1994 and up.
:thumbsup:
good thread, did you do it the way it was first described in that thread? or did you make any changes?
so far i just did the basic loop ... i will be adding a breather this winter
what are your thoughts about it?
as far as what exactly????
the feel is much better
it is a little harder to manuver at low speeds but its tollerable
with the breather it should be a little smoother and easier at low speeds
im not a fan of power steering it generally compensates too much and you lose a lot of road feel
thanks
i think i'll give it a shot. did you use the same parts as them? or did you use other parts?
i used what i had around .... when i redo it with the breather i will be using their setup
Did you pull the engine to loop the PS, or did you just remove the IM?
forgot to do it while i was swapping the engine .... so i did it from under the car
was a little messy but easy enough
