acelottski
Trying to loosen the engine mount bolt to replace the timing belt. Have tried 300ftlb impact wrench. No luck. Will try to heat nut tomorrow and try again. Any special tricks?
acelottski said:To remove mount to replace timing belt on girlfriend's del sol, can't get loose. Have tried breaker bar, then cordless impact driver (300 ft. lbs.). Will try to heat nut tomorrow, but barring that I'm stuck. Any special tricks I should know?
Thanks!
